Coolant Drain Tap??
lowfoon
Coolant Drain Tap??
Post by lowfoon »
Anyone know if the 6n2 has one, if so where it is located??
Re: Coolant Drain Tap??
The answer is no. Are you wanting to drain the system, or just get air out?
lowfoon
Post by lowfoon »
Drain system
All you need to do is remove the expansion tank cap, turn the heater to hot, and disconnect the bottom radiator house on the radiator side. Simple as that :)
