Creaking noise from the back?
aaronon
Post by aaronon »
As I'm driving along I keel hearing a quiet creaking. It sounds like the plastic tray rubbing off it's holder. That kind of plastic rubbing. But that's not what it is as I have checked.
Anyone else suffer this? It's annoying me that I know it's there. Could it be something behind the plastic of the boot door. Behind the plastic which houses the rear wiper thing?
Perhaps it's a common problem and someone could help me out? Is it easy to get the plastic boot thing off?
Thanks in advance for any help.
blazeguarder
Re: Creaking noise from the back?
Post by blazeguarder »
Are you sure it's not just another piece of interior trim that's worked itself loose? Mine creaked for about a week in January but then cured itself. I reckoned that it was the rear trim on my 3 door, which is visibly fitted badly, but it sorted itself before I could be bothered to take a look.
Boot trim is held on with 2 screws, one in each of the hand recesses. Then just give it a pull/carefully prise it off.
Dunno what else it could be, suspension maybe? Worn bushes or something?
aaronon
Post by aaronon »
It sounds like it's coming from inside the car.
What is the read trim is that the same as the boot trim? I guess I could take it off and have a little look inside. :)
blazeguarder
When I said rear trim before what I actually meant was the rear quarter panel by the rear seats on the 3 door. I don't think that there is actually anything behind this unless you have rear speakers fitted. If you've got a 5 door, then clearly there's window winders and all that behind the rear door cards. Would assume that both options are equally easy to remove/refit
aaronon
Post by aaronon »
Thanks a lot. It sounds to be coming right from the back so I'll take of the paneling that is below the rear window. :)
zedzo
Post by zedzo »
its a polo it was born to rattle :lol:
turn up the tunes problem fixed 8)
blazeguarder
zedzo wrote:its a polo it was born to rattle :lol:
So true lol - AC/DC turned to max sorts mine out every time!
aaronon
Post by aaronon »
Lol guys :)
it's not a rattle if some kind it's more a creak of plastic rubbing off something!!
I've just turned on the radio when I drive. I still know it's there though :D
