Cubby box
Gillen
Cubby box
Post by Gillen »
How do you remove the tray at the top of the dash/centre console to fit the cubby box?
Karson3270
Re: Cubby box
Post by Karson3270 »
Where did you get your cubby :O Go round the back of the little storage and try and get a screw driver in and pry it out :)
blazeguarder
Re: Cubby box
Post by blazeguarder »
As said before, use a screwdriver to pry it out. If you've got an old bank card handy, try to use it at the rear corners to lever the back of the tray up - makes it easier to not mark the dash. The main clips are on either side of the rear corners, so get a screwdriver under one, and work along the back until it comes out.
Cubby box is about £40 from the stealers, sometimes turn up on ebay for less. Great bit of kit though, one of the easiest/best mods I've done.
