I seem to still be losing coolant after re-sealing the fan switch, which i thought to be the cause! I can see no visible signs of where its getting out, just hope its not internal!
Any ideas as to common leak points or signs to look for?
Dan
Any ideas?!
Re: Any ideas?!
Check the thermostat housing, the water pump surround and the heater matrix for leaks.
The only other thing is a split radiator or a hose somewhere.
Re: Any ideas?!
i had it running for ages at a stand still and would have thought, if i had a leak, i would have noticed some coolant on the ground after moving the car!
Its doing my bloody head in now!
