one way valve*****
one way valve*****
does anyone know where I can find (online) a one way valve (non return valve) that I can use for my crank case breather?? as it is for the breather it has to operate at really low pressures...HELP PLS!!!
Re: one way valve*****
what about a crankcase breather filter?
I have got that but it is making strange annoying noises from the breather hose!! like it is sucking in air at times...but now I narrowed down the problem to a probably defective PCV valve!! so I should not need the one way valve. tks anyway mate
