how to reste ECU???
dub6n2
how to reste ECU???
Post by dub6n2 »
as the title states how can you reset an ECU of a 6n2 polo pls?? could this be done with vag com ( erasing the DTC or something like that?)
Trunkz
Re: how to reste ECU???
Post by Trunkz »
Disconnect the terminal leads from the battery. Grab a jump lead, and use that to bridge (connect together) the positive and negative terminal leads together. Leave car for a few hours. That oughta do the trick :)
