Hello im in the process of installing my old sound in my new car, but am a bit worried about damaging any panneling.
Wanted to find out a few things:
Where to lead the wire from the battery to amp (with the Washer tubes, or through another opening in engine bay?)
Where to feed the wire from the sub to the headunit (have i got to to remove the glovebox to feed the cable from the floor up to the headunit?)
any thoughts or ideas would be great
many thanks
Amp wire from battery to headunit. Polo 9n 16v 03
Re: Amp wire from battery to headunit. Polo 9n 16v 03
passengers side, under the glove box, theres a plug hole, drill it out and put it through there
& yes the RCA wires will have to be done that way, but run it on the other side of the car to the power wire and the remote
david burton
you don't need to remove the glovebox, just take the plastic trim off from underneath it.
