Hey, ive got a MK4 Polo Automatic and now weirdly when I get in the car I can't change it from Park to Drive. It's like the gearbox is locked and I can't push the button on the side in to change gear! Quite annoying this decided to happen in a petrol station whilst someone was waiting behind me! Quite annoying! Anyone know whats up with it or is anyone having the same problem?
Cheers!
Jamie
Automatic Gearbox Problems
- JangoJamie
Re: Automatic Gearbox Problems
My 1997 6n 1.6 Auto had the same problem. Thought I had big GB troubles just to find it was the knob slider spring. I had to replace the gear knob.
You can take it off (grub screw at side) and change gears by pressing on the shaft. I replaced it with a gear knob from the wreckers but it seems after market ones should fit.
- JangoJamie
Thanks for commenting mate appreciate it! I found out a few weeks ago it was a spark plug that was blown and it just needed replaced! -.- Thanks again though mate!dtulloh wrote:My 1997 6n 1.6 Auto had the same problem. Thought I had big GB troubles just to find it was the knob slider spring. I had to replace the gear knob.
Jamie
