Heavy clutch. Any ideas?
yeah, basically my clutch is really heavy and overall not healthy. What could be the problem? And how much to fix?
Re: Heavy clutch. Any ideas?
Try adjusting the cable
If thats no good, its time for a new clutch as its either worn plates, or the release bearing is shagged.
In any case, the effort needed to do a release bearing, you might as well just change the whole clutch!
I almost pushed my clutch pedal through the floor the first time after I replaced the clutch.
The difference!
I suppose that means mine needs replacing to!?
Im happy with mine as i like it to be harder.
But i suppose that means something is wrong?
Its has a fair bit of pressure to push all the way down, and about half way down it squeaks and creeks.?? Although it passed its MOT a month back?
Sorry to hi jack!
Sorry to hi jack!
could be pedal box failure if it is creaking
f6had
We had this with the 6N2 when I bought it a few months back.. changed the cable first, didn't help..
It basically needed a new clutch - the pressure plate was buggered.
Cheers guys. Will probably get a quote for a new clutch.
Ive always been told that if it still works, theres no point in changing it?
