Brake pedal problem ,please help!!
RS_GT
Post by RS_GT »
Ok guys wondering if anyone else has experienced the same problem, or know a fix
my brakes work fine however when i take my foot of the pedal it doesnt spring up all the way meaning the brake lights stay on! when the brake pedal is depressed i have to pull it towards me so there is no contact with the switch. however it only pulls towards me by about 3-4mm so is the switch too far forward, or is there another solution? any help would be appreciated as im currently having to change the fuse everytime i get in the car
Re: Brake pedal problem ,please help!!
Sounds like the pedal spring is damaged have a look up above the pedal
RS_GT
Post by RS_GT »
cheers Alex, just managed to sort it out, just removed the switch and wiring connector, reattached it following the Haynes instructions and made sure everything was tight.
another problem..sorted! :D
