rear vw badge
rear vw badge
does the rear wv badge cum of the boot? anyone no?
- Drives: 6N2 Polo GTi & 9N3 Polo GTi
Re: rear vw badge
Yes. Either prise it off with your fingers, or use some dental floss. It least an indent.. But no holes.
Re: rear vw badge
u no what 2 use 2put it bak on and wat it luks like off?
Re: rear vw badge
It looks odd. There is a recess for it in the tailgate, so it cant be removed with a clean look. You would use trimtape to refix it
Re: rear vw badge
big896 wrote:u no what 2 use 2put it bak on and wat it luks like off?
Number Plate sticky pads.
when u take the badge off you will see its originally just stock on with a 1mm black round double sided sticky pad!
i tried sticking just number plate tape along the V and W bits but it wasnt strong enuf.
so my boyriend grabbed me 3 number plate sticky pads from vw where he works and its worked a treat stuck on nice and hard.
but they r the same as the ones from halfords but its like £2.49 for a pack.
i would deff suggest double sided sticky pads tho!
at the end of the day its what VW orginally used! and it wont damamge your paintwork
