samco TIP Hose needed with a FMIC?
chris meardon
Post by chris meardon »
Hi Guys
Im a little confused as to what the intercooler pipes replace when i get the forge FMIC
I have commited to buy a samco TIP but it has come to me that if im getting pipeing will the TIP not be replaced by a metal pipe?
Many thanks
9N3 Turbo
Re: samco TIP Hose needed with a FMIC?
Post by 9N3 Turbo »
chris meardon wrote:Hi Guys
Many thanks
When you get the intercooler kit it will come with all pipes except the one off the throttle body.
The TIP you want to buy from me sits on the airbox down to the elbow off the turbo this is not included in the intercooler kit.
noone025
Post by noone025 »
Make sure the Samco one is designed for the Polo, a Mk4 Golf GTI or other similar one is not the same.
Likely could be made to fit, but its a pain to get on without having other issues on top...
9N3 Turbo
Post by 9N3 Turbo »
noone025 wrote:Make sure the Samco one is designed for the Polo, a Mk4 Golf GTI or other similar one is not the same.
The Samco one for sale is defo for the Polo GTI 8)
Gillen
Post by Gillen »
chris meardon
Hmmmmm
May need to look into this a little further. Didnt realise they did one that took the metal elbow out as well.
Have you got one in Gillen? Make much difference?
Gillen
Post by Gillen »
No mate, got the Forge one (not fitted yet). Worth the extra IMO!
chris meardon
How much did you pick yours up for mate?
Why have you got one but not got it fitted?
Hows the miltek treating you? Im going to get one next month and would like your advice on it
Gillen
Post by Gillen »
£120 I think it was mate.
Only reason I haven't fitted it yet is I'm collecting a few bits up and getting them all fitted together (FMIC/TIP/Brakes)
Milltek is really good but going to be changing the centre section from non resonated to resonated when I get the above fitted!
chris meardon
Any reason mate?
Apparentley the non res is the one to go for?
Gillen
Post by Gillen »
Get to many chavs wanting to race me and it's a bit embarrassing driving through the village.
drennan
Post by drennan »
blueflame 2.5" downpipe is the way forward!! got mine fitted sounds spot on. a higher pitched "tighter" noise kinda lyk a mk5 r32 comes out if it must have for all polo gtis :D
chris meardon
just the downpipe? surely you would want the whole system?
r32 noise is incredible, but its all down to the 3.2!
drennan
Post by drennan »
yep just the down pipe mate. yeah i know i want 1 :)
