polo tracking pulling to right probolem
vdub10
Post by vdub10 »
Right got this prob with my car and its realy doing my head in. took it into garage for the tracking to be checked all ok. also checked steering rack and found it wanted some adjustment all perfect. all done. only prob is its still pulls to the right hand side. always thats why i sent it in get it check. they said they cant find out wrong. any body got any ideas.
only one i thought of was if ya push down on the passangers side of car the spring feels harder than the drivers side. drivers side seems to have more spring init as if spring nackared of even shocker.
any body help me?
tom
racerjonzo
Re: polo tracking pulling to right probolem
Post by racerjonzo »
you checked tyre pressures? as if right is more deflated than left itll pull to right more
also ive got 16v springs and shockers if you need replacement ;) just incase you wanna replace them
good luck
vdub10
Post by vdub10 »
mine is an 8v. no both tyre pressure exact same.
tom
thats what i cant get my head around pressure same, tracking 100% and steering rack set up and yet it still pulls to right.
vdub10
Post by vdub10 »
cheers tho m8
racerjonzo
no bother here to help :P
maybe brakes rubbing slightly?
sounds a bit odd but would have to see to pin point, just giving suggestions
you had brakes changed recently or wheels or suspension?
vdub10
Post by vdub10 »
Hiya i have just fitted some new g60 steelys. they are all balanced no vibration etc etc.
Wheni bought car i was told it had new pads on front and in all fairness they look new and have got alot on em.
Its anoying me cos garage cant find a prob so i gonna have to. not a prob but its pin pointing what it is
brakes
wheels
cambor
castor
tracking (which had done)
top suspension mount i hear they wear out un evenly
spring gone soft
shocker leaking
so much
tom
vdub10
Post by vdub10 »
anybody any ideas
all help would be greatful
