Feul pump relay?!
robz
Feul pump relay?!
Post by robz »
Got a bit of a prob with my GT :( the relay (think thats wot it is) that allows the feul pump 2 open when the ignition is on.
Well anyway it was broken & had been using a wire (which had been working fine) bcos i tried 2 a load of diff 1s but none seem 2 work. Any1 nos if you need 1 4 a gt or wood another type do?
retro
You can use others...
Post by retro »
The fuel pump relay is a pretty common type, you can use one from a different manufacturer if you like.
Have a look look at the old relay, it will have a little diagram showing the internal connections. Just find one that has a matching diagram and similar rating.
