starting problem
sid 60
starting problem
Post by sid 60 »
Have a 1999 1.4 Ltr.Trying to start the engine but engine does not turn, can hear a chattering ( maybe a relay type sound) from the engine bay but cannot identify where the noise it is comming from. The dashboard lights also flash on and off when trying. Any suggestions please.
vdub10
Re: starting problem
Post by vdub10 »
hmm flat battery.
just an idea
Battery is dead - thats a definate. The chattering the the throttle body resetting due to lack of power
Get a new battery and your problem will go away!
vdub10
Post by vdub10 »
thought that might have been prob
tom
sid 60
Post by sid 60 »
now the snow is clearing might be able to get a car near for a jump start, this car had a new battery last year so thought that would be OK. Thanks.
vdub10
Post by vdub10 »
give it ago. there the same symptons i was having when i stupidly left my lights on. just jumped it off using a jump pack all good now.
sid 60 wrote:now the snow is clearing might be able to get a car near for a jump start, this car had a new battery last year so thought that would be OK. Thanks.
do not jump start it.
You need to put the battery on a decent charger. If its that flat, a jump start will get the car started, but the alternator cannot provide a solid charging current - it will only provide a top up charge so it will go flat again, and the battery will be damaged
vdub10
Post by vdub10 »
oooow i learnt something todya sorry alex. wrong info given i didint no that to be honest.
sorry
tom
sylvester
Post by sylvester »
Can you justify the above quote?
no wrong info given.
The cold weather will find out a failing battery especially if its over 3 or 4 years old in normal use.
An alternator can provide a strong current for a healthy battery. If the battery is completely flat, due to the current not being intense like that of an external charger, it will partially recharge in the time you are running the car, then start to discharge quite quickly as it has not been charged to capacity.
As I am sure you are aware, car batteries do not like deep discharges, as going flat and recharging on various occasions will damage the plates inside the battery. The plates gain sulphur deposits on them, which can only be 'removed' by a high current external charger - this is known as depolarisation.
Looking back on this, if really needed you can jump start it, however you should take the battery out of the car as soon as you can after your journey is complete and give it a proper charge.
