Interior bulb dead - user replaceable?
dash
Post by dash »
Hi again,
The interior light appears to have died in my car (the one in front of the sunroof). I'm assuming its just a fused bulb but how easy is it to replace myself? Instructions and part numbers for the replacement would be gratefully appreciated ;)
Thanks, Maj
Speedlaw
Moderator
Post by Speedlaw »
It *should* be described in the user manual. If it's not, I believe the unit can be removed from the roof liner by carefully prying in a flat headed screwdriver, popping the light from it's retainer frame. After that the light should be easily replacable.
HTH!
merstham_phil
Post by merstham_phil »
you can buy blue painted ones from a local car place, usuall where they sell exhaust trims, sunstrips, led washer jets, etc etc
i got one some from some place like that....was only a couple quid.
or you can buy blue LED ones off ebay.....
the whole light bit comes out easily....
dash
Post by dash »
Am I removing the light bit from the plastic surround, or the light + plastic surround from the roof lining? The manual isn't too clear :S
merstham_phil
the whole light unit, IE light and plastic surround.....
dash
Post by dash »
Cheers dude, all sorted now, was a piece of cake once i knew how... I think to start with i was trying to take the bit that unit docks in off too though so have a tiiiiiiiny little bit of that exposed... oops :oops:
