I'm new to the forum and looking for a little help on a issue with my 2006 Polo GTI.
At slow speed the steering makes a strange swirling/grinding/creaking noise on full lock or near full lock.
I have checked the power steering fluid level and that's fine, the steering feels fine as well.
Any ideas on what this could be?
Noisy Steering
Re: Noisy Steering
Worked it out after a lot of head scratching!
I sprayed the top mount with GT85 by turning the steering on full lock and using a tube on the can. I also sprayed the ARB bush at the same time and hey presto no creaking!
Re: Noisy Steering
Mine Does it too.....I might just so the same
Although it is lowered on springs
Re: Noisy Steering
Mine creaks and bangs and allsorts but mines down on coilovers. They are just abit of a noisy car it seems! if you search the forum loads of stuff about it will come up!
- beijing polo
Re: Noisy Steering
haha, come to think of it mine too! full lock makes a electronic whining noise, and when the car movse on full lock its a grinding from tyre to arch lining.. its fine mate
Re: Noisy Steering
It got noisy again - turned out to be the strut top mount - the bearing had split
£100 later and all is well!
