Select reverse … more airflow to foot well … a mystery.
RayD
Post by RayD »
Has anyone come across this … when you select reverse on our 2007 1.2 S while the heater fan is on - the airflow to the passenger side foot well increases two fold?
It’s noticeable by the noise it makes … just like changing the fan switch from 2 to 4 but only on the passenger side.
I’ve ruled out the gear change mechanism interfering with the fan speed switch and changing it up a notch or two because it happens even on position 4 … full speed.
Thank you
Ray
POLOZ
Re: Select reverse … more airflow to foot well … a mystery.
Post by POLOZ »
Yup happens in my GTI
BennoGTi
Post by BennoGTi »
When you stick the car in reverse, it automatically turns the recircualtion switch on, so the car does not draw in air from outside, just keeps recircualting the air in the car
Its so when you reverse through the exhaust fumes, they don't get sucked into the car
This is the noise you hear when the fan appears to speed up when slecting reverse
RayD
Post by RayD »
Thanks for solving that mystery Benno.
Ray
POLOZ
Post by POLOZ »
BennoGTi wrote:When you stick the car in reverse, it automatically turns the recircualtion switch on, so the car does not draw in air from outside, just keeps recircualting the air in the car
That makes sense :)
drennan
Post by drennan »
I also recently found this out always wondered. Yeah its a feature not a fault lol
JamieG172
Post by JamieG172 »
Interesting, good to know. Our 9n and our 9n3 do this, so now I know why! Thanks.
Kpb
Drives: 9n3 gti silver
Post by Kpb »
BennoGTi wrote: Fri Jan 28, 2011 3:34 pm When you stick the car in reverse, it automatically turns the recircualtion switch on, so the car does not draw in air from outside, just keeps recircualting the air in the car
huh........well that solves that for me.
cheers Benno
Just like your rear wiper wiping the rear screen when you select reverse and the front wiper is on.
foolhandy
Drives: 9N
Post by foolhandy »
I wondered this to - thanks for the explanation. Makes sense. :)
