helooo 9n forum
my boss's wife has a 9n diesel and the oil light is on and hasnt been serviced in a year, so it needs an oil change.
i offered to do it thinking itll be a simple job and the garage they were gonna use is booked up till tuesday.
can anyone just briefly or via picture to save me time show me where the sump is on it and the oil filter too. and if anyone knows what size hex key i will need
any help is greatly appreciated
polo 9n diesel
Re: polo 9n diesel
Sump is behind the plastic and the oil filter is at the front of the engine I believe mate if that help. I not done service my self. But sounds like there not slot of oil in this thing or the pick up pipe is blocked
Re: polo 9n diesel
thanks, is there a plastic undertray on it then?g__humm wrote:Sump is behind the plastic and the oil filter is at the front of the engine I believe mate if that help. I not done service my self. But sounds like there not slot of oil in this thing or the pick up pipe is blocked
Re: polo 9n diesel
Should be
Re: polo 9n diesel
Ok shuld be simple enough to take off to get to it, don't happen to know the torx size would you ??g__humm wrote:Should be
Re: polo 9n diesel
20 or 25
Re: polo 9n diesel
For the under tray that is
Re: polo 9n diesel
thanks again . im assuming the sump is a similair torx aswell?g__humm wrote:For the under tray that is
Re: polo 9n diesel
Don't know mate I would think it's bigger than that n pos a socket for it
Re: polo 9n diesel
17 or 19mm socket for sump.
Re: polo 9n diesel
19mm on pretty much all VAG sumps, as long as it looks ok you dont need a new washer... well they dont come off so it would be a new sump plug alltogether but its re-usable anyway,
the oil filter is a paper cartridge insert, you can see the housing when you take the engine cover off, to take the lid off the filter housing its either a 32 or 36mm socket or filter wrench/pliers should do it
make sure you get the proper spec oil for it or you're asking for trouble needs to be vw 505.01 or higher i think
easy enough though
easy enough though
Re: polo 9n diesel
thanks very much88rsr wrote:19mm on pretty much all VAG sumps, as long as it looks ok you dont need a new washer... well they dont come off so it would be a new sump plug alltogether but its re-usable anyway,
easy enough though
