Boost gauge - which wire to use for power?
Gillen
Post by Gillen »
Which wire do you use to connect the wire coming from the boost gauge to? I've seen some people use the power wire going to the headlight switch as this allows the gauge lighting to adjust when using the dimmer on the light switch unit...but I don't know which wire!
Harney
Re: Boost gauge - which wire to use for power?
Post by Harney »
I just wired mine into the cigarete lighter socket so that the light comes on with the ignition but thats because mine are the smoked gauges. have a look at thios thread, mite be of some help http://www.vwwatercooled.org.au/f127/gu ... 35780.html
g__humm
Post by g__humm »
Wired mine to the light switch so when u turn ur lights on it goes on. Use a multi meter to get the wire needed.
Gillen
Post by Gillen »
If using the live for the headlight switch I'm assuming the power will only come on when the switch is turned...not a constant so i'll get a flat battery?
Gillen
Post by Gillen »
To answer that...yes the gauge is constantly illuminated if using the live for the headlight switch.
Not sure which one to use!
