Page 1 of 2
Wiring diagram
Posted: Sat Mar 12, 2011 1:41 pm
by Tilo
Hey there guys,
I'm not really an owner but i do need your help.
I'm fitting a speedo and a fuel pump/sender from a Polo MK5 just like the one in the picture. I also have the ECU. What I need now is the wiring diagram to know which wire goes where... I believe the donor engine was a 1.4 petrol.
Is there any chance I can get those?
Re: Wiring diagram
Posted: Sat Mar 12, 2011 6:32 pm
by alexperkins
what are you wiring it too?
Re: Wiring diagram
Posted: Sat Mar 12, 2011 6:45 pm
by Tilo
I want to make it work... Lights, gauges, speed, km, fuel level, engine temp. All the basics.
Re: Wiring diagram
Posted: Sat Mar 12, 2011 6:57 pm
by alexperkins
These are CAN-BUS driven clocks. They are driven mainly by/via the ECU rather than directly from sensors etc.
Re: Wiring diagram
Posted: Sat Mar 12, 2011 9:24 pm
by Tilo
Yes, that's why I have the ECU also...
Re: Wiring diagram
Posted: Sat Mar 12, 2011 10:21 pm
by alexperkins
So is this in a Polo or are you trying to make something work outside of the car?
Re: Wiring diagram
Posted: Sat Mar 12, 2011 11:54 pm
by Tilo
It's a kit car. What i'm doing is to fit the instruments from the polo in the kit car.
Re: Wiring diagram
Posted: Sun Mar 13, 2011 3:33 pm
by alexperkins
Ah I get you
Ill reel off the basic wiring schematics later on. PM me your email address
Re: Wiring diagram
Posted: Sun Mar 13, 2011 8:16 pm
by Tilo
PM sent...
Re: Wiring diagram
Posted: Fri Mar 18, 2011 11:01 pm
by Tilo
Sorry to bother again...
Alex, I've managed to get the turn signals working with your diagram although the wires were swopped, meaning, the black/green wire is actually the right turn signal and the black/white wire is the left one.
This made me believe this isn't the right diagram because some other wires are missing or not working, such as the handbrake signal and illumination.
The donor car was actually a 2001 Polo 6KV Variant 1.4l 16v. Does anyone have the diagrams for that? Much appreciated...
Re: Wiring diagram
Posted: Sat Mar 19, 2011 7:44 am
by alexperkins
Is that a polo saloon/estate
Re: Wiring diagram
Posted: Sat Mar 19, 2011 8:47 am
by Tilo
estate..
Re: Wiring diagram
Posted: Sat Mar 19, 2011 9:07 am
by alexperkins
Ah thats a different wiring set then, as its based on the 6n chassis
Re: Wiring diagram
Posted: Sat Mar 19, 2011 3:14 pm
by Tilo
Is there any kind of fuse inside the dash? If there's not, i might have blown it up!
I've managed to get the turn signals, odometer and clock power and high beam signal working but now nothing lights up.
Re: Wiring diagram
Posted: Sat Mar 19, 2011 4:44 pm
by alexperkins
there may be a glass fuse. Youll have to open it up and take a look
