SDI to TDI conversion?
dub6n2
Post by dub6n2 »
does anyone know if it is a big deal to convert an SDI engine to a TDI VE version(not the PD of course)? Do the parts retro fit such as the manifolds and oil cooling parts? or is the whole block not designed for a turbo and its boost?
or are the TDIs a direct fit in a polo SDI? or do the mountings need to change?
Re: SDI to TDI conversion?
SDIs are not designed for boost. They have a completely different compression ratio and a longer stroke just for starters
dub6n2
Post by dub6n2 »
ahh thought so ... so would a TDI VE be a direct swap with an sdi? would be great to have a 1.9l tdi in a 6n2 :D
nigelelliott394
Post by nigelelliott394 »
I've been dreaming of this for a while :D... except mine isn't an SDI, just a D... whatever difference there is I don't know but apparently it deserves a separate page in the handbook to highlight that it exists.
If you do it I'll follow suit :D
Nigel - if yours isnt a TDI, then it must be an SDI as these were the only two options offered in the 6n2 variant
D models were a 6N idealism and came in 1.9 varieties only
dub6n2
Post by dub6n2 »
nigelelliott394 wrote:If you do it I'll follow suit :D
first I'll have to get my hands on a 6n2 SDI then when I have the funds buy the TDI engine and then do the work :p ... that is if I do not buy a golf mk4 TDI instead of the polo 8)
nigelelliott394
alexperkins wrote:Nigel - if yours isnt a TDI, then it must be an SDI as these were the only two options offered in the 6n2 variant
I've always been confused about that but it's in the handbook as 1.9D.. I get the feeling it was a very early model of 6n2 which shared the same engine from the 6n era perhaps? Not sure but I'll get a picture of the sticker in the boot :)
deebee731
Drives: 2003 1.9 SDi
Post by deebee731 »
In a similar vein - I think that my 2003 SDi 1.9 Polo needs a replacement direct fuel pump. Can I use one fitted to Golf TDi's as there are more plentiful breaker cars in my area?
