gti headlight split
chapip
gti headlight split
Post by chapip »
Is it possible to remove the front of the gti headlight and replace it with new. The light works fine but the lense has an imperfection. Could a normal 6n2 lense be used if possible? Don't really want to fork out for a whole new unit if I can get away with it. Any help would be much appreciated.
joe2612
Location: Guildford, Surrey, Drives: Polo GTI 6n2 Black
Re: gti headlight split
Post by joe2612 »
Yes the front 6n2 casing is the same, You can remove them but you'll need a heat gun, flat head screwdriver and patience.
Heat the sealant up around the casing, then gently prise the cover off with the screw driver. It also helps to use a sharp knive to cut through the sealent. Just be carefuly not to damage the pastics around the casing with the screw driver.
The most common approach is a warm oven - a heat gun could boil and damage the plastic
A hairdryer might be a better approach!
joe2612
Post by joe2612 »
Depends on how powerful your hairdryer is/ how lower setting the heat gun is on :P
Lol
My heatgun has a really low and then a stupidly high setting, so I'd opt hairdryer :P
Verity
Post by Verity »
A warm oven worked perfectly for my mate when she did her headlights
6N2 GTI 00
Post by 6N2 GTI 00 »
Good idea for people with crazed & hazed lenses too, mine simply wont polish out
Wet sanding and plast-x ;) solution to all problems
Verity
Post by Verity »
Very true. I've witnessed magical things using that method
Need to do the Golf ones with that method sometime soon 8)
joe2612
Post by joe2612 »
alexperkins wrote:Wet sanding and plast-x ;) solution to all problems
Spill the beans Alex :)
6N2 GTI 00
Very Interesting stuff, think i'll be having a go at this myself
