Cold starts n engine problems
P0*L0W*
Post by P0*L0W* »
My V plate (1999) 6n has this problem in the morning or cold starts can any1 help plz.
Engine starts and instantly cuts out on every cold start it takes two+ go's to get it started, unless you hold the accelorator pedal down slightly when starting and when its started the rev's are below 1000 untill the car has heated up???
sixen
Re: Cold starts n engine problems
Post by sixen »
vag com it matey, id say theres a temp sensor or throttle body problem
Thats definately the Temp Sensor - common failure on these
When you replace it, be sure to get a genuine one from a dealer and not a copy part from GSF/Euro etc as the quality is just shocking and half they time they dont work at all
P0*L0W*
Post by P0*L0W* »
How many temp switches is there.Thanks
one.
If its a 6n itll likely be a black 4 pin temp sensor with a square plug
P0*L0W*
Post by P0*L0W* »
Iv had the temp switch changed and I'm still having same problem so I'm going to have my throttle body taken off and see if that could be the problem.
Thanks for th advice.
