Cold starts n engine problems
Posted: Tue Apr 19, 2011 7:29 pm
by P0*L0W*
My V plate (1999) 6n has this problem in the morning or cold starts can any1 help plz.
Engine starts and instantly cuts out on every cold start it takes two+ go's to get it started, unless you hold the accelorator pedal down slightly when starting and when its started the rev's are below 1000 untill the car has heated up???
Re: Cold starts n engine problems
Posted: Wed Apr 20, 2011 10:04 am
by sixen
vag com it matey, id say theres a temp sensor or throttle body problem
Posted: Wed Apr 20, 2011 11:05 am
by alexperkins
Thats definately the Temp Sensor - common failure on these
When you replace it, be sure to get a genuine one from a dealer and not a copy part from GSF/Euro etc as the quality is just shocking and half they time they dont work at all
Posted: Thu Apr 21, 2011 11:59 am
by P0*L0W*
How many temp switches is there.Thanks
Posted: Thu Apr 21, 2011 1:11 pm
by alexperkins
one.
If its a 6n itll likely be a black 4 pin temp sensor with a square plug
Posted: Sun May 15, 2011 11:39 pm
by P0*L0W*
Iv had the temp switch changed and I'm still having same problem so I'm going to have my throttle body taken off and see if that could be the problem.
Thanks for th advice.
