what rattles in your polo ive noticed a few cant seem to pin them down though
bit surprised expecting German build quality
still undecided but i think my clio had less
rattles
- Edi30
Re: rattles
None in mine as yet. This is something which I have noticed as an improvement over my MK5 Golf ED 30 both Polo and Golf MK6 have no rattles at alldaydotz wrote:what rattles in your polo ive noticed a few cant seem to pin them down though
Re: rattles
Mine has no rattles (1.4 16v), is 16 months old, does 48 miles to gallon (5.8 litres/100km), has covered 23,000kms without using any oil and has yet to be serviced (due at 30,000kms). It was built in Pamplona, Spain. Maybe yours is a South African one...
Re: rattles
how would i check my dealer said something about where my car was being made but it was so long ago i cant remember although he may have been misinformedGrey_Polo wrote:Mine has no rattles (1.4 16v), is 16 months old, does 48 miles to gallon (5.8 litres/100km), has covered 23,000kms without using any oil and has yet to be serviced (due at 30,000kms). It was built in Pamplona, Spain. Maybe yours is a South African one...
to be fair on the car im looking for as many faults as i can find i hate it
rattles every time i hit a rough bit of road
ive had a few odd issues with the boot not opening the vw badge/handle feels flimsy
i hate reversing it dsg is a pain to reverse slowly
the rear window wiper does not wipe wide enough
the boot struts seem a bit weak
check safe locking even though ive enabled it
Re: rattles
I had a rattle around the odometer. It became apparent after a couple trips to work mainly on rough roads and ramps. There's a small gap between the speedo display and dash easily fixed by dealer with a nice thin bit of foam.
Re: rattles
I know this sounds stupid, but do you still here the rattles with the music off?
A few weeks back i had similair problems heard rattles around the car but couldn't locate it, having turned the music down the rattles had gone
In the sides of the door i had put some random items, and basically the bass from the music was making it rattle, put them away and now i no longer have rattles?
Just a suggestion, incase people made my mistake
rattles
Ive tried a few things with music off
I originally thought it was the parcel shelf so took that out no different I've looked at all the trims nothing is noticeably loose
Im going to empty the car an see if it's something I put in I did wonder if my USB stick was moving about
I can't find where they are
Re: rattles
My understanding is that most, but not all RHD version of the current Polo are made in South Africa. Likewise the LHD models in Pamplona,daydotz wrote: how would i check my dealer said something about where my car was being made but it was so long ago i cant remember although he may have been misinformed
daydotz wrote:to be fair on the car im looking for as many faults as i can find i hate it
Mine has no rattles.daydotz wrote:rattles every time i hit a rough bit of road
The boot requires a certain technique to open it in one smooth movement. But I can't say the badge is weak in anywaydaydotz wrote:ive had a few odd issues with the boot not opening the vw badge/handle feels flimsy
Mine has 'hill assist' and when the foot is off the break, the revs increase to about 1000rpm which allows slow forward and reversingdaydotz wrote:i hate reversing it dsg is a pain to reverse slowly
The rear window is small and were the wiper much longer it would foul the edge of the window.daydotz wrote:the rear window wiper does not wipe wide enough
How? Mine seem fine.daydotz wrote:the boot struts seem a bit weak
I don't understand this sentence!daydotz wrote:check safe locking even though ive enabled it
rattles
Grey_Polo wrote:My understanding is that most, but not all RHD version of the current Polo are made in South Africa. Likewise the LHD models in Pamplona,daydotz wrote: how would i check my dealer said something about where my car was being made but it was so long ago i cant remember although he may have been misinformed
daydotz wrote:to be fair on the car im looking for as many faults as i can find i hate itMine has no rattles.daydotz wrote:rattles every time i hit a rough bit of roadThe boot requires a certain technique to open it in one smooth movement. But I can't say the badge is weak in anywaydaydotz wrote:ive had a few odd issues with the boot not opening the vw badge/handle feels flimsy
Mine has 'hill assist' and when the foot is off the break, the revs increase to about 1000rpm which allows slow forward and reversingdaydotz wrote:i hate reversing it dsg is a pain to reverse slowlyThe rear window is small and were the wiper much longer it would foul the edge of the window.daydotz wrote:the rear window wiper does not wipe wide enoughHow? Mine seem fine.daydotz wrote:the boot struts seem a bit weakI don't understand this sentence!daydotz wrote:check safe locking even though ive enabled it
I've found a bit of trim on the passenger side which says Spain
If you look in the footwell on the left
secret compartment
I've activated auto locking/unlocking
I use to get a warning about checking safe locking I still seem to get this ocassionly
Based on what your saying about revs I can't say my revs change the car seems hold it's self I can take my foot off the brake if I'm moving slow enough an the car won't move on a slope
Wiper I thought I could change it but like you say it's to long now
Boot struts maybe they fine
The vw badge just seems very lightly sprung
Re: rattles
The first problem is that there are no German built polos, GTIs come from pamplona along with some 3 Dr models, the others come from SA.
The major rattle issue stems from the fuel lines rattling against the bodywork, this is a very common issue and every dealer here in australia knows about this fix, yet we hav only had the 6R polo in the country for 9 months, strange that this is not being immediately addressed over there, I though only we had sh**house service from VW!
