spare wheel
daydotz
spare wheel
Post by daydotz »
having had a rummage round my boot ive found a star headed screw driver im guessing this has something to do with the wheels but it appears to not fit is this a a cover over the alloy wheel bolts ?
duffman502
Re: spare wheel
Post by duffman502 »
This is the torx crewdriver you use if you want to take your headlights out with,and do many other things like take of your grill change foglight bulbs etc (you can pull the metal out of the plastic and reverse to change size).
As for wheels if you want to take the dust caps off you should have a little hook type thing in there next to your anti theft socket.
daydotz
Re: spare wheel
Post by daydotz »
cheers
