Forge dump valve.
shawnged
Forge dump valve.
Post by shawnged »
Was wondering if there is any adjustment with the forge 007p d valve??
dood9n3
Re: Forge dump valve.
Post by dood9n3 »
You can change the springs
BennoGTi
Post by BennoGTi »
It comes with one spring suitable for standard + stage 1
Then you can get another spring for stage 2 onwards
shawnged
Post by shawnged »
Yeah i did realise the spring can be changed its probably not worth it as my car has only had a re-map thanks
drennan
Forge dump valve.
Post by drennan »
BennoGTi wrote:It comes with one spring suitable for standard + stage 1
Didnt relise there was another spring advised for stage two where would i get one of these? How great are the benifits?
dood9n3
Post by dood9n3 »
http://www.forgemotorsport.co.uk/conten ... =FMDVSU110
http://www.forgemotorsport.co.uk/conten ... ct=FMDVTUN
BennoGTi
Post by BennoGTi »
Iv been looking into it and there are more than just the two springs:
Green - 6-8 PSI
Yellow - 10-12 PSI
Blue - 14-16 PSI
Red - 18-20 PSI
You can buy them direct from Forge.
I was also wrong, the Standard (Green) spring is just for a standrad car, so I should probably get mine changed to Yellow!
EDIT:: Ahh dood just beat me to it! :)
drennan
Post by drennan »
Ok cheers guys! However 1 more question, has anyone done this? And recomend a spring color setup for a stage 2 revo polo? Ops thats 2 questions lol
