I have an error code "01539 - Headlights Not Adjusted 35-00 - -"
Please bear in mind i have replaced the sensor arm and one of the headlights, which i suspect is entirely the reason for this code.
I am also aware of the procedure to align them, as described on the rosstech site http://www.ross-tech.com/vag-com/cars/x ... nment.html
If i do as detailed on the rosstech site will this solve my error code?
Headlight 'home' setting with VAGCOM
Re: Headlight 'home' setting with VAGCOM
Yes it should
The new motor probably hasnt had basic settings and adaption run on it yet, therefore it will error till its done
Agreed, this is my thinking here to.
However, something bothers me slightly that you may be able to shed some light on, forgive the pun.
When i had my last 2 MOT's they have tried to manually adjust the offending xenon and have wound out the hex bolt fully but the light was still pointing down in the testing box thing they use for MOT.
Surely this should have lifted the beam temporarily before it reset to its unadjusted home, shouldn't it?
The adjuster in the headlight may be broken - its a common problem on the 6n2
Put the 55 - Xenon into learning mode, try setting the height and see how you get on
i hope not as that headlight was bran spanking, fitted it only last year!
Yes mate. Those measuring blocks aren't used here
Ha, amazing screen background. What a player. 1994 world cup, best ever!
Dunno if this helps you or not mate but this is the link from Ross Tech regarding headlights and adjustments for the polo:
http://wiki.ross-tech.com/wiki/index.ph ... Adjustment
Thanks, Neil
No worries mate, hope you get it sorted, i messed about with mine using vagcom once and it took me nearly two weeks to find that page so i could lower them again.
