Advice - TOP MOUNTS
POLOZ
Advice - TOP MOUNTS
Post by POLOZ »
My topmounts will be getting replaced next week and I am wanting some info on which ones to go for?
I have heard, you can get cupra ones but not sure.
whitegtipolo
Re: Advice - TOP MOUNTS
Post by whitegtipolo »
just get standard ones
Isaac39
Post by Isaac39 »
I agree. My driver's side rear top mount split and were replaced with standard ones and they've been fine.
Monkey-Man
Post by Monkey-Man »
Im assuming your driving a 6n?? In which case the cupra ones will indeed fit as they share more or less the same chassis (with the exception of the ccupra subframe being wider to support the wider track width).
But yes the cupra ones will fit, me though as said abovem just stick to your standard ones. If you have the money go and get a genuine vw part as they are known to last longer than the counterparts that places like gmf, gsf etc sell but never the less keep to your standard top mount, just makes things easier!
POLOZ
Post by POLOZ »
Monkey-Man wrote:Im assuming your driving a 6n?? In which case the cupra ones will indeed fit as they share more or less the same chassis (with the exception of the ccupra subframe being wider to support the wider track width).
No mate drive a 9n3 GTi hence why its been posted in MKVII section :P
Well I checked up and mk4 cupra and the 9n3 have the same top mounts and bearings :) so think will be sticking to the OEM ones.
Monkey-Man
Ahh s**t yer :P What a c0ck i am!! :P
Havent got used to how this forum works yet :P Just click view new posts and away i go without paying attention to anything :P
But still apllies, could use cupra top mounts, but id just stick to your standard part! VW part if you can stretch to spend that little bit more.
