I knew it wouldn't take long lol
4 months in to Polo Ownership and ive given in, Im booked into have a Miltek Catback system and a Remap & DSG Tune Done at Viezu Technologies at the end of the month!
What gains have other seen from a map?
Started Modding
Re: Started Modding
I was working with Viezu here to try and see if their remote tuning systems work or not with the new, MED 17.5 ECU fitted to the GTI, unfortunately, the V-Switch doesn't work. If you could provide a bit more info for us aussies because Viezu isn't a well known brand here and there are a lot of people ready to blow them away, funnily enough they're either owners of APR tunes or work with APR...... But that's another story.
Will the Viezu tune be a full ecu-removal bench tune, or still online but using the Kess V2 system? Would be handy if you could find out...
Viezu will make a tune for your exact needs so how much power you want really is up to you, the beauty of the Viezu tune is that it's bespoke to your car, nobody else will have the same tune. Most tunes out there are starting at the 155Kw / 300Nm mark...
