Remote Locking
ali123
Remote Locking
Post by ali123 »
Does anyone have a guide for an RClick remote locking kit. I have seen Alex Perkins has one for a 6n2 but they are probably completely different. So does anyone have any advice or even better a guide?
ali123
Re: Remote Locking
Post by ali123 »
Nobody?
rasA4
Re: Remote Locking
Post by rasA4 »
i wouldnt bother with rclick you would have to splice into the wires. i went down the OEM route works out more but a lot better without splicing/scotch locking wires
bought a central locking module and 3 button remote bought a flip key cut all from eBay. then carefully cut out the transponder from the original key.
you will need VAGCOM to program the cent locking module.
ali123
Re: Remote Locking
Post by ali123 »
rasA4 wrote:i wouldnt bother with rclick you would have to splice into the wires. i went down the OEM route works out more but a lot better without splicing/scotch locking wires
Thanks for the advice but there isn't anything wrong with splicing wires if you know how :wink: and you don't need to program it with vagcom either
rasA4
Re: Remote Locking
Post by rasA4 »
Each to there own I think you will access to the fusebox.
Id check with the seller as instructions are not car spefic
Let us know how you get on.
