Lookin to put a cone air filter directly onto the maf, leaving everything else as standard, bottom of airbox and cold air feed.
Anything else i need to change on the car while doing this? Seen a few people talking about putting mini Oil Crankcase Breather Filters on too.
Its a 2006 1.2 Polo
Cheers for any help.
HELP....cone air filter.
Re: HELP....cone air filter.
if you get a crankcase filter with the kit you can install it also.
otherwise don't bother, you can also just put a filter on it.
but if it's oil based, don't put to much oil on it because it can damage the maf sensor.
(not sure a 1.2 has a maf sensor??)
