Shcoks
- NeilMcConville
Shcoks
Ordering H&R Lowering Springs soon, anyone got advice on getting upgraded shocks to go with them or any other ideas?
jonnymoore
Re: Shcoks
how much do they lower by?
- NeilMcConville
Re: Shcoks
25/40, but i heard they have been changed to 20/35 cause they dont drop as much
jonnymoore
Re: Shcoks
ahh, i ordered a set last week. 35/55. got an email sayig they had to be ordered in from germany and they wont be there untill early next week then takes another week for them to get over to ni.
- NeilMcConville
Re: Shcoks
Aw that sucks :/ are you getting shocks with them or just keeping the standard ones?
jonnymoore
Re: Shcoks
just keeping standard ones lol shouldnt really need to get differen ones
- NeilMcConville
Re: Shcoks
Thats what i was thinking but i dont want anything happening them cause their will be no warranty on them
jonnymoore
Re: Shcoks
spose. i havent really thought about the shocks tbh lol. where abouts you from?
- NeilMcConville
Re: Shcoks
I dont think ill bother tbh cause ill just take a bit more caution with bumpy roads and potholes :L em northern ireland, you?
jonnymoore
Re: Shcoks
saves some money
same here. which part?
- NeilMcConville
Re: Shcoks
Yeah it would!
Em Co. Down?
Em Co. Down?
Re: Shcoks
Lowering springs from reputable companies generally keep the same overall spring rate (bar the rears becoming progressive rate) so your shocks will be fine. If you go too low though, then you will build pressure in teh shocks and cause premature wear by the piston not working in it's optimal damping range.
- NeilMcConville
Re: Shcoks
Definitely wouldn't be going too low cause i'd not be able to get into my drive, mud flaps are constantly scrapping on it and id say if i got the 35/50 springs the skirts would start catching so 25/40 it is
Der Finne.
Re: Shcoks
From personal experience I can say that the H&R 25/40 are perfectly driveable with the standard (non-sport) shocks, but would benefit from shocks with a slightly stiffer rebound damping especially at the front. The spring rates are somewhat higher than standard, so the front of the car tends to bounce higher than necessary on rebound, when going over speedbumps or similar 'humps'. The bounce was amplified after fitting the lowering springs, so they're definitely higher rate than standard springs since the shockers remained the same.
To get the last few mils out of the springs, be sure to loosen the bolts that the suspension arms pivot around. Only retighten them when the car has the new springs and is back standing on its wheels.
And as for the original VW mudflaps: If you have the long 'elefant ear' versions, VW now sell shorter ones. No more scraping.
- NeilMcConville
Re: Shcoks
Thanks mate
