Hi all,
I have a Y reg 1.4 16v 6N2 polo and whenever I run it, both the engine warning light and the EPC light come on. The EPC light goes off when i turn the ignition off but comes on again when i start it, being a bit of a pain.
Does anyone know how to fix it or what it could be?
Any help would be greatly appreciated
Alex
EPC and Engine warning light
Re: EPC and Engine warning light
Would be best to get the car scammed with a fault code reader or vag.com. Ive just got rid of my EPC light and it turned out to be the brake light switch on top of the pedal, very easy to change .seems to be a common EPC fault.
hope it helps abit
hope it helps abit
A-brownpolo91
Hi chris, thanks for the help and info, had the car scanned with VAGcom and the engine check and EPC light are related to a fault on the manifold pressure sensor. I also had the ABS light which came up when testing it which was a fault with the speed sensor on the rear wheel.
Alex
Alex
