dash clock/ service ind.
oggy
Post by oggy »
The clock on the dash keeps going back to 0.00 every time the ignition is switched off and the service indicator will not reset even after a service granted not at a vw dealership,how do i resolve the problem ?
Speedlaw
Moderator
Post by Speedlaw »
Sounds like thers's a problem with the battery. If you turn the ignition off, the power gets cut and the clock goes back to zero. Alternatively, there could be a fault in the car's ground (minus cable) so check that as well.
HTH
oggy
Post by oggy »
Thanks 4 the advice don't think theres a battery problem well only that theirs no starting problems will get the cable checked out,any ideas on how to go about that ?. cheers
Speedlaw
Moderator
Post by Speedlaw »
Simply open the bonnet and check out the connections of the battery. The terminals should be clean and firmly in place. Also check the ground coming from the battery to the chassis, if its connection is rusty or loose, it may cause intermittent power losses.
Col
Post by Col »
Do the clocks make a whirring noise when u turn the key?? Check the fuses for the clocks in the fuse box, happened to mine :wink:
oggy
Post by oggy »
Yes they do Col will check it out and let u know.
oggy
Post by oggy »
Cheers 4 that Col fuse had gone,replaced and everythings tickety boo.
