Boot popper??
Rom Tasburn
Boot popper??
Post by Rom Tasburn »
So i wired in a boot popper to my car and it works fine:) always opens the latch and now my boot can go completely smooth:) BUT my boot doesn't pop out enough to get my hand under to open i have to dig my nails in above the lights and claw it open, has anyone got a solution, i have seen on some cars small springy rubbery things that push open the boot but i cant find where to get them from or what to search for. Many thanks Tom
Trottagti
Re: Boot popper??
Post by Trottagti »
You should have 2 on your boot already mate. There for adjusting the gap and height of the boot.
Pull the rubber of and you should see an alen key. Simply undo it a bit and pull the clip out a bit then do up the bolt and repeat on other side. Put the rubber on and that should aid your opening.
Rom Tasburn
Re: Boot popper??
Thanks thats great!!!
