Awryty peeps
Car broke down 2 nyt lost power then wee puff a white smoke them wudny start it was just crankn. So a ran a vcds n it said engine start blocked by immobilizer went to start it n it just went thump then nothing asif its seazed.. :s any thoughts? Its not run dry checked engine oil and thought it mite of been the timing belt but that was changed bout a year ago check it just to be sure and its fine not snapped and teeth look ok. This is the vcds code
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
Readiness: 0100 1100
