POLO SDI FAULT CODE 17911 help
Saddo
Post by Saddo »
Hi all
My wife's 2003 polo sdi is throwing the following code.
17911 P1503 Load signal from Alternator Term. DF Range/performance/Incorrect Signal.
It stuggles to start some mornings from cold but otherwise runs ok.
Any ideas???
Tony
Bickerton
Re: POLO SDI FAULT CODE 17911 help
Post by Bickerton »
17911/P1503 - Load signal from Alternator Term. DF: Range/Performance / Implausible Signal
Possible Causes
Alternator faulty Voltage Regulator faulty Wiring and/or connections faulty
Possible Solutions
Check / Replace Alternator Check / Replace Voltage Regulator Check wiring and connections Check the fuse box that is in the battery tray, it might be burnt, the fuse or the complete plastic box (pretty common failure on Sharan because it carries so much electrical load). If so, change the complete fuse box, it is not too expensive fix if this is the cause.
Saddo
Post by Saddo »
Wow, will have to wait until the dryer weather, also read that a yellow wire can become damaged under the car......
Tony
Bickerton
Post by Bickerton »
Yeah is check for loose wires first before you buy a new alternator etc
K.I.T.T.
Drives: Bicycle
Post by K.I.T.T. »
When you turn the ignition on (without starting the engine), does the battery idiot-lamp light up in the instrument cluster?
Ash
Saddo
Post by Saddo »
Hi, sorry for late reply, yes the light comes on as stated in above post.
Tony
