jon_poloV
Sponsor
Posts: 825 Joined: Sun Feb 22, 2004 3:18 pm
Post
by jon_poloV » Mon May 31, 2004 11:19 am
hi there
if i had 17 inch wheels that were an ofset of 35 would the rub if lowerd by 40mm om springs and dampers.
the tyres are 205 40 17
if they would rub what would they rub on?
the plastic of the metal?
cheers
jon
carmadaaron
Posts: 4350 Joined: Fri Mar 12, 2004 8:55 pm
Post
by carmadaaron » Mon May 31, 2004 7:41 pm
yes 17s will rub.
go for 16s.
KarlM
Posts: 2353 Joined: Mon Oct 14, 2002 11:11 pm
Post
by KarlM » Mon May 31, 2004 7:49 pm
on a mk4 they would rub on the rear bumper (where it joins to the body) and most of the plastic liner.
One technique is to spray some bright paint on the inside of the arch, go for a drive, take the wheel off and see where the paint has rubbed off
carmadaaron
Post
by carmadaaron » Mon May 31, 2004 7:56 pm
good idea
jon_poloV
Sponsor
Post
by jon_poloV » Mon May 31, 2004 8:44 pm
when you say yes they will rub are we talking plastic or metal cos i could just take out the plastic inners!
jon
MIZ VW
Posts: 17 Joined: Thu Jun 03, 2004 12:57 pm
Post
by MIZ VW » Thu Jun 03, 2004 2:31 pm
stick with 15 or 16, it depends if u want the euro look to b honest.
ive got a mate with one on 17 and she cant have no-one in the back as it rubs bad.
keep them small i say
carmadaaron
Post
by carmadaaron » Fri Jun 04, 2004 7:48 pm
15s,16s wont rub at all.
17s will fit but with some arch work!
clear enough?
jon_poloV
Sponsor
Post
by jon_poloV » Sat Jun 05, 2004 8:41 am
carmadaaron wrote: 15s,16s wont rub at all.
clear enough?
dont take the p*** mate your just saying the same thing! you have not said if it rubs on the metal or plastic! if is plastic is not a prob but with the metal it is.
jon
carmadaaron
Post
by carmadaaron » Sat Jun 05, 2004 10:22 am
with 17s itll rub in the front top (bit nearest the door) metal of course!
the car will "bottom out" and hit the metal arches at the back. if carrying loads or going fast over a bump.
carmadaaron
Post
by carmadaaron » Sat Jun 05, 2004 10:28 am
with 16s if u go for 195/40/16, they wont rub at all. (metal or plastic!)
however, tyres are expensive
