Spark plugs ?
lukey GTI
Spark plugs ?
Post by lukey GTI »
I have just put a full decat exhaust system on my polo :P Sounds mint feels a bit more responsive too
It could do with a service soon and some one recommended I change the spark plugs He told me to avoid a certain make but I cant remember what it was .
Any advice ?
Tsineas
Re: Spark plugs ?
Post by Tsineas »
Hello there, I bet your foot is more heavy now so you can pleasure your ears.
About the sparks plugs when I did stage 2 and serviced the venichle I
Purchased the Audi S2 ones because the run colder.
Im at work now I have the part number at home I can post it later today.
rover220
Re: Spark plugs ?
Post by rover220 »
get ngk pfr6q. these are standard fit. if you want to go colder you need pfr7q
dood9n3
Re: Spark plugs ?
Post by dood9n3 »
spend a little extra on NGK BKR7EIX and you will be happier
lukey GTI
Re: Spark plugs ?
Post by lukey GTI »
Tsineas wrote:Hello there, I bet your foot is more heavy now so you can pleasure your ears.
yeah you are right about that :lol:
dood9n3 wrote:spend a little extra on NGK BKR7EIX and you will be happier
thanks lad do i just quote that at a vw dealer or parts place
TehSniper
Re: Spark plugs ?
Post by TehSniper »
http://www.camskill.co.uk/m18b571s1232p ... 667_/RS_GB
found these on camskill.co.uk, not a bad price and reliable place to deal with
Tsineas
Re: Spark plugs ?
Post by Tsineas »
So here you go the S2/RS2 Spark plugs part number incase !
101000016AA
Mr Blobby
Re: Spark plugs ?
Post by Mr Blobby »
Whats the benefits of colder running spark plugs?
rover220
Re: Spark plugs ?
Post by rover220 »
Mr Blobby wrote:Whats the benefits of colder running spark plugs?
Less chance of pre det,can run higher boost.
Downside is they put more load on the ignition system in general.
lukey GTI
Re: Spark plugs ?
Post by lukey GTI »
TehSniper wrote:http://www.camskill.co.uk/m18b571s1232p ... 667_/RS_GB
I think these are the ones i was told to stay away from
dood9n3
Re: Spark plugs ?
Post by dood9n3 »
I doubt dealers sell this one, its more and aftermarket upgrade item
Tsineas
Re: Spark plugs ?
Post by Tsineas »
Just get the rs2/s2 ones they might be pricey but worth imo.Original parts is always Original!
As I said above I use them myself non-problemas!
Edit: Just Quote this "101000016AA" at WV/Audi at Reserve parts or so.
9N3 Turbo
Re: Spark plugs ?
Post by 9N3 Turbo »
I have been using the S2 plugs mentioned above for years with no issues.
Great plugs
