Hey everyone I was just wondering if you could answer my two questions
1) how much psi should a standard gti be producing
2) how much psi should a stage 1 gti be producing ( I know every map is different just wanted a rough idea)
How much psi should......
Mr Blobby
Re: How much psi should......
Standard PSI at 7 psi (0.5 bar) and when i got my stage one done it peaked at 19 psi and ran normally at about 11 psimorells wrote:Hey everyone I was just wondering if you could answer my two questions
Mine standard peaked around 11 and held 7, now it peaks about 21 and holds 15-16
after software peaked at 1.6bar (23psi) and settles at 1.4 (20psi)
seriosuly confused and a tad worried since it's substantionaly higher as the tuner also mentioned this.
