Second gear crunch
v896
Second gear crunch
Post by v896 »
Hi all
Recently started to get a crunch when changing into second gear all the rest are fine has anyone had this issue? if so would anyone recommend a company that repairs gear boxes ?
many thanks
quinnygti
Re: Second gear crunch
Post by quinnygti »
2nd gear syncromesh has worn, when changing gear the worn syncromesh isn't slowing your gear down so it crunches, does it crunch if you select 2nd really slow?
v896
Post by v896 »
Hi
Thanks for the reply any idea how much it would cost to replace ?
quinnygti
Post by quinnygti »
Quite alot unless you have a good mechanic m8! if u took the gearbox out yourself that would save costs parts will be quite alot as its vw probs around 500 quid if u took box out yourself :(
v896
Post by v896 »
ouch that sounds like a mission thanks alot for the advice much appreciated
noone025
Second gear crunch
Post by noone025 »
It's not a fix, but may help, there are 2 Redline gearbox oils that help with the crunching, depending on the year of your car, one is better. Come have a search in the VWW forum for info.
v896
Post by v896 »
What the type of gearbox oil used for a 2006 polo GTI?
