Hi, my mothers CEL came on so she went and had it scanned and it came up with a fault with the EGR valve. I want to try and clean it out before she has it replaced, to see if its just stuck open/closed. But the problem is I'm not use to these engines, can anyone explain where the EGR is and how easy it is to remove on the engine? Oh ye its a 2009 (9N3 possibly?) 1.4TDi blue motion.
Any information will be greatly appreciated, thanks!!
1.4TDi EGR Valve
vincentvdl
- Drives: Polo Bluemotion
Re: 1.4TDi EGR Valve
I was looking for the same info, it was hard to find.
Here is the detailed instruction in Spanish with pictures:
https://www.furgovw.org/index.php?topic=250784.0
Use an online translator if needed.
Screws for the valve are T30. Replace rubber ring after clean-up.
The most difficult will be to remove the valve after you have removed the screws.
Good luck,
Vincent
Good luck,
Vincent
