Drivers Front Seat
ss03947
Drivers Front Seat
Post by ss03947 »
Hi, I've a 53 plate Polo, 1.9 diesel, I've had it a while now, & the edge of the drivers seat has worn away exposing the foam material inside...so it needs replaced.
Question for the guru's;
Do I have to replace the seat with a original Mk4 driver seat. :?:
or; can I fit a Golf/Passat etc, something with a bit more comfort/style/height adjustment etc. :?:
Also if you can, is it a bog standed swap, or is there a few tweeks to be done. :?:
Not up to speed on these things as you may guess.. :oops:
Thanks in advance..
SS
ss03947
Re: Drivers Front Seat
Post by ss03947 »
3 weeks & 23 views, & no replies.. :shock:
Someone must have an idea... :D
You can fit anything from a 9n or 9n3 polo
Some seat ibizas and skoda fabias will fit too.
Anything else can be made to fit, but welding is required.
