What would I need to do to make an offset 53 wheels fit?
- jamesagordon
As titled, interested in a set of wheels but they are ET53, I'll need to run adapters on them anyway but will they go on? I'm s**t with offsets
Re: What would I need to do to make an offset 53 wheels fit?
With about 20mm should be able to?
Example
The standard offset is approx 35mm, a Porsche wheel has a higher offset of approx 55mm, therefore to fit Porsche wheels to your car and retain the factory VW offset you would require a 20mm spacer which will still retain an offset of 35mm. Increasing the spacer thickness allows you to space the wheel out further giving the car a more chunky wider stance.
Example
You cannot say that!
Offset is dependant on wheel width, The spaces available for suspension arm clearance, any camber adjustments & arch clearance.
A different width alloy will have a different offset.
OEM offset is ET46 on a 7" wide rim.
First thing we need to know is how wide the alloys are & then if you are sticking with stock size tyres.![Cool 8)](./images/smilies/icon_cool.gif)
- jamesagordon
wheels are being postponed unfortunately due to some s**t yesterday so I won't be getting these anymore!
.??. What's happened James?jamesagordon wrote:wheels are being postponed unfortunately due to some **** yesterday so I won't be getting these anymore!
![Shocked :shock:](./images/smilies/icon_eek.gif)
- jamesagordon
jamesagordon wrote:PM'd you
![Smile :)](./images/smilies/icon_smile.gif)
