Boot led bulb
Boot led bulb
Just a quick question what bulb is in the boot? Is it a capless 501 or festoon?
KieranLeighton
Re: Boot led bulb
501
remove th fuse before putting it in as they pop them iirc
Re: Boot led bulb
Where is the fuse? I wonder if it will blow if you let the boot light turn off then change the bulb as then it wouldn't be drawing any power.
Re: Boot led bulb
I'm sure you can jus disconnect the whole unit then swap,out the bulbs!CANDYMAN wrote:Where is the fuse? I wonder if it will blow if you let the boot light turn off then change the bulb as then it wouldn't be drawing any power.
Re: Boot led bulb
Just plug it in. No need to remove the fuse.
- stuart.cameron
Re: Boot led bulb
501. Remove the unit then put the bulb in.
