Polo 9n1 1.4 TDi Coolant temperature sender
akz786
Post by akz786 »
Hi
Was looking for a DIY on this and could not find it on the 1.4 Tdi 9n1? - I seem to have located it on the right hand side of the engine facing in from the back somewhere, seems really difficult to get too. I will need to remove pipes around MAF airbox area...
I think I could just pull the horseshoe clip out and the pull the electrical connector off and replace?
All help appreciated
fonzooorooo
Re: Polo 9n1 1.4 TDi Coolant temperature sender
Post by fonzooorooo »
can't tell you where to look on your engine, but yes to the method - unplug, unclip, pull out, (don't forget O ring seal!) new one in, clip back in, plug back on. On the petrol, you have to plug diagnostics in to "tell" it you've changed it. I presume the TDI needs the same.
