I've got a problem with my GTi that when the car is cold it starts fine, but when it's been driven for 5 minutes it takes 2- 3 times longer to turn over and start.
I have changed the coolent temp sensor as this seemed the most likely but I still have the same problem - all suggestions greatly recieved.
Strange Starting Problem
Re: Strange Starting Problem
Was it a genuine sensor? Aftermarket sensors can be hit and miss sometimes!
Yep - fitted a genuine one to make sure of this.
Is there only a water temp sensor in the radiator or in block aswell on these?
