polo not choking
polo 16v
polo not choking
Post by polo 16v »
polo 98 1.4 16v
from cold no choke it starts ok but some times it stalls
idling at 850 rpm
before this problem it used choke from cold at 1000 rpm and
after warm up it came down to 850 rpm
can some 1 help me with this problem
thanks
polo 16v
BenMMellor
Re: polo not choking
Post by BenMMellor »
polo 16v wrote:polo 98 1.4 16v
idling at 850 rpm
thanks
polo 16v
sounds like a similar issue to mine.. mine seems to like idling at 1k rpm
slso when sitting at lights it'll flip between 1.5k and 1.8k rpm..
i think the throttle body is either fecked or gunged up. going to try the advice i've been given alreeady on here and clean it - failing that just get it replaced under my RAC warranty.
polo 16v
Post by polo 16v »
ok i give throttle body clean and see what happens
is there any adjustment after clean
thanks
polo 16v
Speedlaw
Moderator
Post by Speedlaw »
Either a dirty throttle body or a faulty temp sender. The sensor is located on top on the thermostat housing, most VW dealer should know what you're talking about since this part goes bad very, very often.
The result is rough or too high idling, sometimes stalling, etc etc.
You don't need to reset the TB if you leave it in place. If you take it off, I've been told you DO need to have it reset.
